PowerRam1987
- Warwick, RI
testing the waters to see if theres any interest. may have the opportunity to go one ton.
-HP D30 just sandblasted/bed lined, new ball joints, new unit bearings "hubs", new pinion seal, new inner axle seals, 4.10 r&p/carrier, aussie lunchbox locker, 1/4" thick go rhino diff skid that goes under the housing
-ford 8.8 from a 97 explorer,31 spline, 4.10s, lincoln locked (done well), spring over, disc brakes, all new brake lines/fittings, extra set of calipers/pads/rotors, solid diff cover, welded on all the seams-axle tubes/housing/etc, painted black
-would also be selling my 33x12.50 MTs on black d-windows 2 are 75% and the other 2 are about 40-50%
-Rock Krawler HD steering (basically OTK) with heims would be sold with the D30 and an extra set of knuckles or separately from axle i suppose
-also have another HP D30 (disconnect style) with a cable lock and 3.73 R&P open diff
-another go rhino 1/4" steel diff skid that will fit under a D30 or D35 comes with brackets, will probably fit a chrysler 8.25 pumpkin too
