bmyohn
- Lake Orion, MI
I am in the process of placing a fuel cell in the trunk. I have the adapter to use the original fuel pump and sending unit. I have no issues extending the wiring into the trunk. But I am not sure what to use to extend the fuel lines into the trunk. From what I have heard/read there is quite a bit of fuel pressure in the metal lines. I was planning on just using rubber fuel lines but am not sure if it will hold up to the pressure.
What do you guys recommend using that will hold up to the pressure?
Thanks!
Thanks!
