knockedout88xj
- Brooklyn,MI
I have an 1987 cherokee with a 4.0 it has 266,000 on it and i was wondering what was the best fix for exsessive blow by in the front valve cover tube.
I'm not disagreeing with TiRod, but you are on the way with the first step by making sure that the vacuum side of the breather system is clear. If you search some, you can also find threads where people have rigged up systems to reduce oil in the air filter.
