Stukboy
- Lancaster, PA
OK, let's start with the basics:
I have a 92XJ with a stock 4.0,AW4, 231 with a SYE.
I removed the airbox and installed a "cold air/air tube and cone filter.
I also run a Holly fuel pump speced for my engine.
The issue is:
When I turn the key, it will crank, it will briefly fire/start but then as soon as I let off the key(return to "on" position) it will stall.
Even when on the gas it will stall out.
I have fuel pressure at the rail, I changed the crank sensor on the bellhousing, i replaced the distributer and cam position sensor and changed the plugs.
Oh yea, it does have gas in the fuel cell.
Any thoughts?
What should I check next?
Thanx for any input,
Stukboy
The issue is:
Any thoughts?
Stukboy
