engine trouble
stxcherokee
ok one more try...
The other day i was out mudding and thought water in the intake and dist. was the cause of the xj bogging down i guess you'd call it.
well yesterday on the same trail, my buddies told me to haul and romp, so i did, but it was only down a rocky road no mud/water.
Once again the engine bogged, not as bad as w/ the water hole before, but still a bit of bogg.
Where do i start searching for this problem. Seems fine now on the road, but back on the trail have that same prob. Want to fix it before i get stuck out on the trail.
Could it be my dist, plugs, wires.. or is it a fuel issue.
remember only happens while going down the trail, mud and all, no mud or water in dist or intake.
help please
I'd check fuel-pump (pressure) and or replace fuel-filter
Runs OK on the road (level, minor hills) but bogs on the steeps...
Had this same problem, but on a Mercedes ;-) Swapped fuel-pumps (and filter) and WoW! what a diff.
I had a very similar problem in my YJ when I was in Florida. Turned out I got a little water in the Throttle Position Sensor....sprayed it out with WD-40 (which helps displace the water) and it was as good as new in about 2 days. Now I just carry a spare one with me for sh!ts and giggles.
