This might be stupid but how does the pcm determine engine rpm. Its not from the distributor or cam position sensor because if you unplug it while the engine is running it does not change anything.
quick hijack-- when the CPS determines RPM and sends it to the tach, will the signal work for a 6cyl and a 4cyl? I guess what I'm wondering is if a dash cluster from a 6cyl can be used on a 4cyl and vice versa??
Interesting. On the Renix the IP tach picks up the signal from the negative side of the coil for RPMs. I believe on the 91+ its fed from the PCM.
Did you have a particular year in mind?
EDIT: looked up the 87-90 parts, and the tach is engine specific for the Renix, just like any aftermarket tachs that aren't adjustable, it must be for the correct no. of cylinders.
Boo Hoo-- that makes life a little tougher-- that's what I figured, but I was hoping against hope that the tach was using a CPS signal that was converted to a tach drive by the ECU-- no dice:rattle:
I have an 87 2.5L and switched to a gauge cluster I think from like a 96 but not sure. The tach works but does seem off. So probly from a 4.0L ... is there a way to confirm and maybe fix?
