Get or make a couple of studs to help line things up when you reinstall the head, it will go a lot smoother. I actually took two of the old driver's side bolts (I'm using all new head bolts) and ground the heads round to the same diameter as the shaft of the bolt. They will be plenty long enough to remove easily after you get the head and gasket back on the block and some new bolts in place.
