Seeing if someone could help me narrow this down.
I have a high pitched howl coming from the front of my engine. It only happens at idle, atleast i can only hear it at idle, as soon as I give it gas it goes away, but then it may just be that I can't hear it over the engine noise.
Anyway, its towards the front, it is also intermitant, I have narrowed it down to the top, center, or passengers side. It seems to be the same with the ac on or off, and it is not the electrice fan.
My thoughts are water pump (6mos old), AC, or the mechanical fan. I loosened the belt to check for a wobbly pulley but found nothing.
Any Ideas on how or what else to check?
