N nonnie NAXJA Forum User Location Cape Breton, N.S. Canada Nov 12, 2007 #1 I cycled the key three times. The ck engine lamp flashed 17 times. Anyone tknow what that would mean?
Saudade NAXJA Member NAXJA Member Location SoCal Nov 12, 2007 #2 Yeah, you counted wrong. There should be a small pause in the flash sequence. These pauses denote the different numbers. For example (1 denotes a blink): 1-11-11111-11111. Would be 13 blinks and represent codes 12 and 55. Yours could be OBDII (not sure about CA models). If so, you can use a regular code scanner on it.
