i'm going to re-do the lights on the back of my rig. the lights that i plan to use have 2 bulbs inside each housing, each with its own positive lead (and one common ground). i want to run a three way switch in an on-off-auto fashion.
when the switch is in the "auto" mode, i want only one of the bulbs in each light to activate through a relay tied to the OEM reverse lights. when the switch is in the "on" mode i want both bulbs in each light to activate through a relay tied to a continuous power source.
the following is a diagram that i think will work (it's rather obvious that i'm not an electrical engineer).
the purple circles with arrows are supposed to be diodes.
my first question is, will this work?
my second question is, do i need another diode where the big blue arrow is?
my third question is, what kind/type/size of diodes do i need?
TIA.
TIA.
