stephenspann27
- College Station, Tx
I had to remove a broken piece of a trans/motor bolt.. and when doing this I dropped the front drive shaft, and also removed the bracket off the drivers side of the transmission that holds the shift linkage for the T-case. After doing this.. you can easily reach your hole hand/arm up there and get to the CPS easily.. must easier thank dropping the trans cross member and using extensions and a swivel..
I have a pic.. I"ll get uploaded later.
