bmyohn
- Lake Orion, MI
I am looking to upgrade from my mechanical cooling fan and flimsy/broken auxilary fan to a dual fan set up. My radiator measures 11.5 inches from top to bottom. So I believe I am looking for a fan that is 11" in diameter, but for every fan that I see the shrouds seem to be 13"+ in height. So my question is, should I just buy two seperate 11" fans with no shroud and mount them directly behind my radiator, or buy a 11" dual fan setup with a shroud and cut the shroud down to fit on my radiator?
Secondly, is wiring up an electric fan simple or should I buy the relay/wiring harness with the 185/195* thermostat settings?
Thanks!
-Brendan
Thanks!
-Brendan
