Drop Brackets
cheapcherokee93
<----boat-manche
Guadalahabra, CA
older drop brackets for sale, not sure on brand. very similar to the rubicon express drop brackets, but doesn't have braces that run under the frame rail. complete, comes with most of the hardware. will get some pics when it stops raining. $100
located in la habra
bling bling lol
Where the stock control arms would have gone, so that you don't overcompress the drop brackets.
Here's a picture of the RE kit, shows the spacers.
You could make them out of just about any material.
Same difference then. It was a good kit. The RE braces will work with them, may require a little massaging.
Exact same as RE. Different paint job.
I thought so too but, they're slightly different......different enough that the RE braces wont just bolt up.
You'll need to fab up a 1/2" thick spacer for between the brace and where the caster adjustment shoes orignally mounted (I used 1/2" thick flat bar) as well as elongate the t-case bolt holes as the braces need to sit 1/2" further back but....no big and well worth the extra work to fit my $15 "bumper brackets" I found at PAP :D
Still, $100 is a great deal.
GLWS
Hans
I have the braces if someone buys your brackets I'll let the braces go cheap, just send 'em my way via PM
