DoctorK
- Roanoke, VA
I've read through the forums and have narrowed down a problem to my front drive shaft. I noticed that it has been mentioned that I should remove the drive shaft and see if the problems go away. I am curious how long it is safe to drive without the front drvie shaft in place. Im thinking i'll pull the shaft, see if the problem goes away, and then fix the shaft, but it may be a few weeks before i can get it back in. I just dont want to make anything worse by not having it in there.
88 XJ 4.0L, NP242, stock.
