my2monkeys
- Mission Viejo, CA
Trying to check toe-in after new tie rod install. If steering wheel is not centered, how do you know if wheels are pointing straight ahead? Pitman Arm at right angle to axle is a good starting place? This is with new TRE installed and toe-in or out of spec. Then do I adjust t:huh
e from there or am I doing it wrong? Thanks for any input.:huh:
