OnorOffroad
- Enterprise, Alabama
I recently installed a 9" in the rear, no shims. I have an SYE and a double cardan DS. At about 45mph under load there is a slight but noticeable vibration and increased humming noise. The vibration only occurs under load, and seems to stop at about 55 or 60.
My guess is that I need to shim the axle to correct the pinion angle, but when I took the measurements it was only 1-2deg different between the DS and the pinion. Would that be enough to make it vibrate like that or should I be looking at something else?
Thanks.
Thanks.
