boomhauer
- Vancouver Island
Hey fellow XJ'ers, I have no vibes @ 5.5" on a 96 4door, AW4, NP231, D30, 8.25 29 spline axles with 33 bfg mt's and t-case drop. I just purchased a HD SYE anyway and would like to purchase my drive shaft BEFORE the installation. Now, apparently Tom Woods has a way to measure so the shaft can be ordered ahead of time. Has anyone done this? Did it turn out to be the correct length? Are Tom's shafts any good? The grapevine says that they are Chinese shafts and are weak. Any truth? Would you recommend installing the short shaft then measuring joint to joint or should i feel safe pre-ordering the shaft using TW measurements and his driveshaft? How is the service and if you have needed to use warranty, how was the experience?
PORC or TW driveshafts, or any other recommendations for that matter?!:cheers:
