@dam said:
OK...so here are my new questions...
-How can I tell if my springs are sagging? I have 145k miles.
-Does that AAL make for a stiffer ride?
-What is easier to install: AAL or Shakles. I'm a mechanically minded person, but not very experienced with a lot of car repair (just the basics...water pump, brakes, starter solenoid...little things like that)
-Will the Budget Boost make other parts, like U-joints, bearings, etc. wear out prematurely. All these parts are stock on my Jeep, so I'm a little worried about them breaking at an inopportune time.
-How much will my speedometer be off by running 30 or 31" BFG A/T tires? My stock tire is 225/75R15.
-Somebody said the shakles cause interference with his exhaust. Could you please be more specific?
-Will the boost in the front create any problems with sway bars, steering linkage, various rod-ends, or any other parts.
-Can anybody be more specific about the MPG loss from running a BB with 30" BFG All Terrains? I average about 18 or 19. I get about 21-24 on the highway. I used to get about 10% better mileage until I moved to CA this summer. I think it must be the gas here. Oxygenated maybe? (I noticed the same loss in my Honda at the same time)
-What sort of speedometer error can I expect? How hard is it to recalibrate?
-What shocks can I get. I think the shocks on my car are stock! They actually seem to work OK...the ride isn't bouncy. But still- that is a lot of miles, and it seems like there will be some sort of sacrifice having the shocks extended 2" beyond what they are used to. 2" less negative travel I'd guess.
-How is suspension geometry altered? It seems like the steering knukles would get pulled in a little, changing the toe angle.
-Oh yeah...unrelated, but what hitch do you guys recommend?
Thanks again for all the input guys.
-Adam
The fender flair edge to rim center measurement will help identify the condition of the current springs.
The AAL will add to the spring rate (make the rear suspension stiffer).
The long (full length) AAL adds minimal stiffness to the spring, although it adds the stiffer spring rate immediately in the compressed travel range compared to the static ride height (it will feel stiffer regardless of the load, compared to the stock suspension). Most people report that the feel is firm, but not rough, because the increase in spring rate as each leaf in the pack is loaded is the same as stock.
The short AAL adds spring stiffness as well, but it adds the extra rate after some initial compression travel. The step, from the stock spring rate to the increased short AAL rate, is more noticable by the driver. and the shock load of the increase in rate is also felt by the stock leafs (it can fatigue the stock leafs). The unloaded ride is the same, but it gets harsh as the short AAL is loaded.
The shackle & AAL lifts are about the same in difficulty, and seem to take about the same time for a first timer. The age and corrosion of the XJ will have more impact on the difficulty than the actual installation steps (as Eagle mentioned, the AAL install involves less corrosion prone bolts to slow a planned install). Preparation with anti-sieze and lubricant spray applied to the bolts and nuts in the weeks preceeding the install really does help.
The BB does not increase wear, but as with all lifts it changes the wear patterns on bearing surfaces. The driveline u-joints will be working at a slightly higher angle, possibly outside the normal wear range, and this may highlight an existing need for a replacement that was not as noticable before the lift.
Alignment is needed after any lift change, and after the springs settle. Alignment of the toe-in is good practice on a regular basis because the XJ's inverted-y steering changes the toe-in with lift height (with installed lift height increase or sag related loss of height). Adjusting toe-in is a good skill to learn, and the accuracy needed for the XJ straight axle is possible with a good tape measure and a long straight edge (a 2x2 wider than the XJ will work).
Most XJ speedometers report a speed faster than actual. Changing the speedometer gear to correct error is easier than changing spark plugs (although it can be dirtier).
Longer shackles sometimes extend down near the tailpipe support bracket near the rear bumper, and hit the tailpipe. Jeep changed the exhaust a few times so some hit, and some do not. Having a muffler shop bend the tailpipe is an inexpensive solution.
Anytime you increase the weight on the steering and suspension, install larger tires, you increase the potential for wear. If we didn't have power steering we would be feeling the extra stress in our arms, and the increased stress is still there with power assist (it's just not transferred back to the driver). If you have a part in need of replacement, it usually dies quickly after a suspension or tire change (not because of lift induced problems, but due to the change in wear pattern and increased weight). Most Death Wobble reports are immediately after a lift, because the mix of new and old parts is not as cooperative (for dampening) as a combination of well worn parts.
The oxygenated fuel delivered to urban areas in CA is reported to reduce fuel economy ~5% (you are not imagining the loss of economy).
Most 3" lift shocks are stock length. Keep the stock shocks, with 0-3" lift, until you revise the mounts. Lifts above 3" can really make good use of extra shock travel, and if you go higher it's the time to select something better suited for your driving style.
BTW, welcome to
, and California. More than a few California people visit these boards (and are
members) with similar transportation needs as you. Providing a balance between a rock/mud/sand/trail crawler and a daily toy hauler is an area where the XJ shines. For every 33 and 35-inch plus tired XJ owner posting on these boards there are probably ten more owners with 30's or 31's (and almost all built XJ owners started in the same situation). The mildly built XJ on 31's performs very well as an all around utility vehicle for 90% of the trails and conditions that can be legally driven. Add-in body protection, minimal fender trimming, and lockers, and the limitation on passible trails is more ground clearance (and budget risk) related than anything else.
