tetsulo
NAXJA Member #1239
- Western, MA.
I completed the first 500 miles on my Golen Stroker today. (I picked it up last Tuesday) I've been considerate and haven't asked too much out of it yet. On the way home this afternoon I noticed that my oil pressure was low. I pulled into a Jiffy lube as soon as I could. To my surprise, the dipstick registered no oil whatsoever. When they pulled the filter and drained the pan about 2 quarts came out.
Sometimes when I start the truck (not necessarily when it's cold) a puff of bluish smoke will come out of the exhaust -- but that's all. It does not appear to be smoking under acceleration.
I'm running Valvoline 20w50 as recommended by Golen Engine Service. I replaced all hoses and the radiator and pressure bottle (1990 Jeep Comanche) with the new engine.
When looking under the hood today I noticed that the pressure bottle seemed darker than it was. I let the truck cool off and pulled the cap off the pressure bottle. There are some black deposits on the inside of the bottle. However, there doesn't appear to be oil floating in the coolant. The deposit seems more like a rubbery compound rather than anything else -- flashing off the inside of the hoses or something? Grease or flux from the new radiator? I would think if the headgasket were bad I would split/blow a hose or the pressure bottle. Temps on the truck seem to sit around the first notch on the gauge -- the one below the 210. I've seen it go another half towards the 210 in stop and go traffic.
I have a 180degree thermostat, a hesco hi flow water pump and a 3 core copper radiator.
I also spent 30 minutes under the truck while it was on a lift looking for any obvious leaks -- there were none to be seen.
Is this normal or excessive for engine break in? If normal, how long will this last?
Sorry for the lengthy message but I'm trying to answer as many questions as possible in advance.
Matthew
Matthew
