SINCITY192
- Bronx, NY
"Bringing the crankshaft around to
zero degrees top dead center (TDC)
compression, I removed the cam sensor
and checked the hole in the vane
where it was supposed to line up with
the hole in the housing by inserting a
toothpick through both holes."
i copied this from a article i found searching for shut off problems and i really would like to give this a shot after i get it running again I know how to bring it to Top Dead Center (TDC) but where is the cam sensor located and where are the hole that he's talking about?
thanks in advance guys
