ItZaJeePThiNG
- Pennsylvania
Ok this has been buggin me for some time now.
I have a 90 xj with a D30 up front. all stock. The passenger side u-joint is shot. it has over an inch of freeplay in it and then the tire will turn. it makes noise and simply needs replaced.
I'm currently replacing the oil pan, Rear main seal, gaskets and pickup tube, So I have decided to finally replace the bad u joint up front while working around the area.
Looking at the POS while connected to the jeep I cannot see any snap rings like on my driveshaft.
I dont know if this u-joint can be taken out and a new one swapped in or does the whole axle shaft need replaced? I searched the zones website and found soo many different u-joints and also front axle shafts(expensive)
can someone tell me if these u-joints are serviceable or do i have to bite the bulletand replace entire axle shaft?
http://www.autozone.com/N,11200178//shopping/partTypeResultSet.htm
ohh ya. i do NOT have ABS
