barillms
- Eastern Ohio baby!
www.offroadoverstock.com
8 rings for $230, that's pretty tempting.
I was running a narrow 32x9.50 TSL tire last year and loosing my bead often, sucks pretty bad especially in muddy ruts, they seem to pry them right off there. I even did it on a side hill on a small 4" stump that hit perfectly. POOF! Gone, no air. It felt like my Jeep almost tipped it dropped so fast!
Running 12-14 pounds too! I popped a 12.50 off a 7" wheel also 3 times the same season. Getting tired of stopping everybody for 20 minutes to swap to my spare and having to go home and clean 40lbs of muck out of my good tire.
They mention the wheel may have to be modified, grinded down along the very outer lip if it has a lip. The inner ring needs a true flat surface to sit on once welded around the outside. Doesn't see too bad of a project.
I would recommend for any DD, but for an off road only this seems nice for about $60 a wheel. Other places I'm seeing the kits for $80-130 a wheel.
Another good thing is it widens the wheel about 2" too. So you could do this to a stock Jeep steelie and make it a 15x9 almost. I think I might do it.
