Does any one know what changed from 95 to 96 on the 4.0 six cylinder engine? Are they interchangable, what issues would I have in dropping a 95 engine into a 96 XJ Body?
The pistons rings changed from standard to metric from 95 to 96. You can drop and 95 engine in a 96 without any problems. You will need to use the fuel system off the 96 since they also changed from a return type to non-return.
The computer system changed from OBD-I to OBD-II, so some of the sensors might be a little different, but I don't for sure. I think the CPS may have changed? And the 96 uses only one temp sensor in the thermostat to feed the ECU and run the dash temp gauge.
