YELLAHEEP
- Littleton, Colorado
Ok, I went to the emissions testing facility and my jeep failed. Now I need to get the repairs done within 10 days to keep from having to pay for a re-test. Here's what the printout said the test limits and results were:
The first numbers are the limits and the second are the results:
HC gpm = 4.000..........4.7023
CO gpm = 25.0000......27.7562
NOx gpm = 9.0000......9.2414
Now, it was around 40 degrees outside and the Jeep was at operating temperature. But, I've never made a habit out of going to the test stations when it's that cold out in the past so I don't know if it's more likely to cause a test failure with it being that cold out. The kind of test Colorado uses puts the vehicle on a dyno and the equipment sniffs the exaust while an operator "drives" the vehicle at different RPM's and speeds.
I'm thinking that in order to cure these problems, I'm probably gonna have to replace the Oxygen sensor, and then tune it up with plugs, wires and such.
Any other ideas? Things I should check or fix?
Thanks in advance!
Troy
Thanks in advance!
Troy
