The jeep fans are hydraulic, not bi-metal spring types. Anecdotal way, when the engine is cold like from overnite start the engine, the fan should roar for 20 or so seconds then quiet down. Thats the fluid redestributing.
FSM method, you need a long thermometer, drilla hole down between the leading edge of the fan and the rad core. Drop the thermostat down the hole so there is air flow going over it. Watch the temp goe up to operating temp. Block the front of the radiator with cardboard or something to stop air flow, watch the thermometer get hotter as engine temp climbs. Remove the air flow blockage and again look at the thermometer, you should see the temp drop several degrees. The FSM has the exact numbers but thats the FSM way of testing it, at least in my 98XJ and both wranglers..
