Daystar extended bump stops
rocknxj
Daystar polyurethane extended bump stops. Part number KJ09101BK. Although they were never installed, I tried, then quickly discovered they fit the 2.5" tubes. They are in like-new condition. I paid $27.95 at Summit Racing (easily found on a ton of other sites).
$15 to the first one who needs them and willing to miss their next two meals at Burger King.
Here is a stock photo of the same item.
What are the lengths on them and how do they instal on the jeep? My extended bumps are screwed into the tube I believe and all chewed up now. Do these just slide into the tubes or do they have a different mounting system. I don't know what mine are and I've been trying to find replacements
These are 5" in length and 2" wide at the part that is inserted into the tube. I have learned that there are two different tube widths on XJs. One is about 1.5" wide and use the smaller bump stop, and one is wider that uses the 2" wide bump stop. I am selling the 2" wide bump stop.
These are installed by simply pushing into the bump stop tube. No mounting hardware is required. Remove the coil spring, insert the bump stop into the coil, reinstall the coil, and work the extended bump stop into the tube by pressing upwards until it seats into place. Once the spring is seated, you can probably use a long screw driver as a lever to push the stop into place.
For comparison, here is a photo of the 1.5" wide extended bump stop that fits into the narrow tube (the one's I should have bought):
