Big Red
- Roscoe, IL 61073
Dana HP44 & Ford 9" axles 4.10s locked with long arm & beefy trackbar setup
Nice dana full width dana HP44 & Ford 9" axles with ford radius/Ruff Stuff heavy duty long arms with heim end (3 link long arm)...will include the frame end bracket mount so you can weld them up and bolt into a MJ....or a XJ with a little work (rear spring perches are different then XJ I hear) but same SOA setup.
$2000 OBO on the pair of axles with stock HP44 steering, long arms, Ruff Stuff double adj track bar ($270 new), also newer 6" Rubicon Express coil springs....so this is a plug and play upgrade for someone.
I wish I had this setup on Big Red in my avatar pic years ago on the Rubicon instead of weld on RE suspension system for the HP44 and then running their drop brackets and adj short arms...cost way too much $ doing it like that and still not having long arms.
Dana HP44 front axle with 4.10 gears and lincoln locked and newer Warn hubs
Ford 9" rear axle with 4.10 gears and limited slip and drum brakes both 5 on 5.5
Troy 815 222 nine four 0 nine
Located in Roscoe, IL 61073
