AJPulley
- South-eastern MA
Hey you guys who put in 44s, did the U-bolts seem a bit big at first when you put it in? Mine are about 3 1/8 inches on the bottom of the U-bolt, and the tube is maybe 2 3/4-2 5/8 I think?
Where did you get them? Sounds like you got u-bolts for a Mopar 8.25 axle -- they have larger tubes, and the u-bolts have a different part number than D44 u-bolts.ajpulley said:Hey you guys who put in 44s, did the U-bolts seem a bit big at first when you put it in? Mine are about 3 1/8 inches on the bottom of the U-bolt, and the tube is maybe 2 3/4-2 5/8 I think?
tetsulo said:Sounds like your u-bolts may be a little large.
Matthew
sidriptide said:sounds like Rusty is just being cheap and using 1 u-bolt for more than 1 application.
44 is 2.76, 35 is 2.64. They fit, so they're on.Eagle said:D35 u-bolts shouldn't fit a D44. The D44 tubes are larger than a D35 but smaller than an 8.25. They are three different part numbers from the factory.
You can't knock success. party1:ajpulley said:44 is 2.76, 35 is 2.64. They fit, so they're on.
Yup. I don't remember why I kept those, probably were the wrong size for the 35!Eagle said:You can't knock success. party1:
