Dana 30 things
eflores
Greg's place
NEW TNT Customs truss with:
stretch buckets
high clearance LCA brackets
both UCA mounts
high steer full crossover trac bar bracket
Retail $551
asking $400
ARB air locker used
3.73 and up in good working order
27 spline
$400
WJ knuckles with JKS spacers already welded on
included caliper brackets and teves calipers
rotors to match as well
cut and sleeved tie rod for wj swap on xj can be used OTK or UTK
cut and sleeved drag link with RHD TRE for flipped otk steering on xj
$150
2 BNIB HA597449 timken wheel bearings
these are the correct bearing to use with the WJ swap
$100 for the set
HP d30 housing
no knuckles or brakes
$50
HP30 USA standard 4.88 gearset NEW
$100
TeraFlex 4959101 and 4959102 New
sway bar mounts. what you would need to run a sway bar with high steer on a d 30
$100
Gently used Yukon 4340 chromo shafts
inners outers and cold forged spicer joints
$500
Looking for:
31 spline selectable 9" locker. arb zip etc
79 HP44 alloy shafts
HP44 4.88 gears
located in Fountain
Flores
eflores - your PM box is full!
How much is still available?
Just got off the phone with Flores, everything sold.
