sherifabdelazziz
- egypt
Gents
i need your advice .. i have 2001 xj with limited slip differential ,however it is now making high noise and as i installed OME suspension with 3 inc lift and 265/75 R15 tires ,i was thinking to change the ring and pinion set ..now i have 2 choices either to get the stock OM replacement or to get other after market replacment with higher ratio .. what is the stock ratio and what would you advice regarding the replacement kind and ratio ?? thanks
