ReftonsRed
- Pennsylvania
After making a few calls i located a 87 XJ w/ 44 rear and 4.56 gears. To run this ill need to match the front w/ 4.56's and I can buy the front axle with those gears for less than new ring and pinion and intall kit. The junkyard guy I talked to wasnt sure if this XJ had the NP242 or ABS (im hoping it does for the 297 ujoint and non disconect) My question comes then if the Dana 30 is a disconnect with the 260 series u joint is a swap possible and if so can I use the shafts out of my current 30 (98 Xj) for this. Also if it would save me time and money in the long run to just use the gears from this axle in my current one let me know.
