Jhumphrey
- Nashville, TN
Hey all,
Doing a little research and cant find the answer to my question, which is:
Are front axle housings interchangeable between ABS and non-ABS models?
I ask because I may have bent axle housing. If this is the case, Ill have to find an entire assembly at the JY. My XJ had ABS, but the dana 35 was changed out with a Chrysler 8.25 by the PO. So, since I currently don't have ABS, if I do swap in a "new" assembly, I want to go with a non-ABS model. I was just curious if I had to swap calipers, discs, etc. or what.
Currently, all the ABS "plumbing" appears to be on the XJ. I simply havent had the want or need to pull all of it out. Im just trying to get the best deal I can and it seems that my local JY's want more for an ABS assembly than a non one.
Thanks all!
Thanks all!
