d44 axle seal- Is it seated?
d10shun
Az
'87 30 spline cherokee Dana 44 axle drum brakes. I just put new bearings and seals on and I am putting the shaft back into the axle. Is the axle all the way in? There is 1/8" of the seal sticking out past the drum backing plate. I tapped it with a mallet but nothing changed. I also made sure to put the correct length axle on either side.
http://d10shun0.tripod.com/cherokee/index.album?i=13&s=1
Don't flame if the pic doesn't work. It was fine in the test forum.
SHould the bearing be lower or what? There is 7/16" clearance from the seal to the lip of the axle flange.
Crash - where is the shoulder?
http://d10shun0.tripod.com/cherokee/index.album?i=15
Just in case.
