OverlandZJ
NAXJA Member # 101
- Bristol,PA
Hey guys, newb here to this kind of work. Been reading up some in the FSM, BillaVista's article.
I'm looking to swap the Dana 4:56 gearset from my HP30 to a new housing. I suspect the current housing is tweaked. The gearset is out of the old housing.
Lets talk tools first. I have a dial indicator, caliper, bearing seperator, and both inlb (thanks mofo) and ftlb Torque wrench's. I figure i need to run over to Harbor Freight and pick up a 12ton press. From what i'v read i dont need a pinion depth gauge.
I have a dremmel to make up setup bearings. Also have an install kit.
What else do i need?
Do i need to make all 4 old bearings into setup bearings?
