D30 for sale
souske
Dana 30 HP, non disco with trussed housing
WJ brakes with EBC yellowstuff pads, rotors redrilled for 5x4.5", Teeves Calipers (will clear 15" steel wheels)
JKS WJ tie rod and drag link, knuckles have Goferit inserts flipped for OTK
JKS OTA trackbar mount, with shortened RE trackbar one pretty new heim and one good spare heim, RE frame side trackbar mount included.
Inner C's gusseted
4.10 gears with Aussie locker, Ruffstuff Diff cover with countersunk bolts and drain plug
Swaybar mounts raised 2"
LCA skids
Currie JJ passenger side UCA, NIB rubber bushing for DS upper
Chromoly axle shafts with 760x ujoints with full circle clips
This axle is pretty much a bolt in and go!
Asking 1200
I believe I emailed you off craigslist. I have a dana 44 with all the fixings, just needs to be put together. Are you interested in a trade? Narrow trac dana 44 from a wagoneer, tnt customs truss, warn locking hubs, ford 5x5.5" spindle, rotors etc. New 4.56 gears, carrier, and install kit...
I'm pretty sure he's not. He's selling because he just installed a new 9" front axle.. ;)
and for the record, I don't really need anything other than the axle itself.
Yes, I didnt hear anything back from you, so I figured it was time to broaden my audience.
As Cal said, I dont need any axle parts in trade, as I just finished putting in a HP9" front, and 8.8 rear. Would consider a good set of 37's.
I don't really want to separate the parts, unless I can get commitments from folks to buy all the pieces.
It depends...
My steelie with 3.75" bs cleared. The al ones I tried with 4" bs would not.
vanimals al clear fine with 3.25 bs
