D30 Ball joint up/down play normal?
Mike1331
Folsom, CA
So when i lift my front tires up w/ a jack and put them back down i notice up/down movement in my knuckle ball joints. Is this normal?
It says in a description on the napa website that up/down play is normal. I think this is the first time i've jacked up my jeep while actually looking at my ball joints/knuckles while lifting.
Ummmm, maybe for a worn out joint.
Last time my XJ was on the alignment rack, the tech showed me some up/down play. It was barely perceptable, but there. I drove it to my bud's house replaced the joints, no more "clunk" sound coming from the front end.
NAPA Premium, FTW!
I am going to "Assume" you are jacking the truck up by the axle tubes or center section and not under the knuckle itself.
Either way...
Neither in/out or up down is "Normal".
Replace lower joint. Upper joint is eventually a pin.
