custom LCA mounts
THE_OWL
Who here has done the D44 or D60 swap and didnt use the RE bracket kit?
Im sure theres a lot of you.
Anyone have pics?
I wanted to try a "other than stock" location probably a bit higher
Any of the custom fab shops sell them? Poison Spider, Avalanche, foothill etc.
thanks for any help
\\hoot
It's pretty easy if you want to build your own arms. Get some 3 x 3 x 3/16 tubing and use JJs on the ends of some tube arms. You'll get better flex & have some bitchin' mounts. The JJ uses a 2.625 width inner 'ball' inside the joint & will fit the tubing, just cut arcs to fit the axle diameter & control arm ends. You'll be GTG.
