Currie steering setup with 1 ton ends
premoxj
San Diego, CA
I dont need this unit anymore. its cut, sleeved and gusseted for 1 ton rod ends. the rod ends are in ok shape but couldnt hurt to be replaced. i have the inserts. i dont have any pictures but if you email me i can send some back off my phone
$150
[email protected]
$150
[email protected]
Hey Jason. I emailed you yesterday from CL. I am interested in this and would love to have 1 ton TRE. But i will need to find a way to rem. the knuckles right? And other then that it's still stock enough to use on my stock Dana 30?
A picture would be great too :-)
Thanks,
Brandon
InlandZJ and Brandon77 is looking for one.
Thanks Cali!
Thanks,
Brandon
hey dude, did i email you back? sorry, work has been hectic so i've been a little forgetful as of late lol if i did, give me a ring tonight
you would need to drill our your knuckles, that is correct. i have the inserts, the drill bit and even a drill press you could use if you want. up to you.
i dont really have a computer right now as my work computer is down so i'm borrowing someone elses until IT fixes it. i can text you over whatever though. i'll PM you my number
You can drill them and add inserts and flip them when you do.
yup! that is correct. you can put the inserts in whichever direction you want then spot weld them into place. you drill the knuckle out 3/4 or 7/8. i really dont recal off the top of my head...i have the bit and the inserts though. its a package set :)
Hey Jason,
I got a stock set up Currie steering from Eric on here. I appreciate the deal. This one is for someone else.
Thanks again, Brandon
