SPXJ
- El Cajon, CA
For Sale Currie "Currectlync" steering. $280.00
In great working condition. All ball joint are tight and also comes with a new drop pitman arm.
Located in El Cajon CA. (SoCal)
![](/proxy.php?image=http%3A%2F%2Fi411.photobucket.com%2Falbums%2Fpp194%2Fspatag%2FCurrie%2520Steering%25202.jpg&hash=10025eda5e923a6f22a2046ebed908fe)
![](/proxy.php?image=http%3A%2F%2Fi411.photobucket.com%2Falbums%2Fpp194%2Fspatag%2FCurrie%2520Steering%25201.jpg&hash=6016647c4911f783a5706cf096820e94)
Currie's web site description:
The Currie Currectlync® heavy duty tie rod and drag link system for TJ, LJ, XJ, and MJ vehicles features, a 1 ¼" diameter forged alloy drag link, and 1 ¼" solid alloy steel tie rod bar that is bored and threaded on the ends. All 7/8" thread tie rod ends with boots are included as well as the Currie heavy duty steering stabilizer bracket. This unit is a direct replacement for the stock parts. No modifications or machining to any part of the vehicle is necessary. This unit is rated at 200% stronger than the stock components. NOTE: This unit is designed to be used on vehicles with 4" of lift. It can be used on vehicles with less lift, but the vehicle must have a minimum of a 2" bump stop (over stock). Also, on vehicles with no lift, 2 of the tie rod ends may need be trimmed to achieve proper adjustment. Weight: 35 Lbs, Height: 6 In., Width: 6 In., Length: 48 In.
