vetteboy
- morganville, nj
I finally decided to pull the trigger on a Currie Anti-rock kit. I had a few situations last time I was out wheelin where it would have helped, the rear springs are noticeably softer than the front, and the body roll on the road is pretty bad. So I ordered up the 44" universal kit w/17" arms to install in the rear.
First thing was to come up with a way to mount the main tube to the frame. I used some 2x4 rectangle tube and a 1.75" hole saw to accomplish this.
Weld it up and throw the bar in.
Weld on axle tabs, cut the links to the proper length, paint & install.
This was probably the most straightforward project I've done in a while. Everything went perfectly start to finish, and I had the whole thing installed in less than 5 hours. Currie included all the nuts and bolts you need to hook everything up, and the only thing I had to actually fabricate were the frame mounts for the tube.
I took it out for a brief test drive on the road up to around 55 MPH; the difference is amazing. Body roll is easily half what it was and I don't have nearly as much torque lean as it used to. At this point I'm totally happy with it, and I figure once I get to try it wheeling, if I don't like it, I just unbolt it and I'm no worse off. Right now it's on the setting for the least roll resistance, so I can tweak it to be stiffer pretty easily just by moving the links further back on the arms.
Definitely a great product, and I think it'll do everything I was looking for. Updates to come after the weekend of Nov. 9 (next trip).
