Crysler 8.25 Fitting Larger Rear Wheel Cylinders
markaboo929
Mooresville,NC
I am trying to fit a slightly larger rear wheel cylinder.The stock ones are a 13/16" bore size.I am thinking 15/16" or would settle for the 7/8" ones.I know,I know...ZJ Discs,but,for a tight budget for even a slight brake increase would be awesome.Stock set up just does not cut it.No lift stock tire 2 wheel drive does not even compare to my 88 set up.lifted 8" on 35's with dana 44,Exploder rear disc set up,ZJ guts in prop valve....that thing stops on a dime!!!!
Sooo anybody done/thought of this route?
Would the master push enough volume to make use of a larger cylinder? Or would you be sacrificing throw for pressure, and not getting them to adjust often enough?
Sounds like there's a lot of testing and experimentation that should go along with it. Discs suddenly sound more effective again to me.
