Yes, I've searched and can't seem to find what I need.
My cruise on my 2000 XJ works fine when it works. No surging or vacuum related issues. This is electronic.
Usually 5-15 minutes working and then it shuts itself off. The green light on the dash goes off and that's it. It acts just like it would if you hit the off switch.
Once it shuts off, it will NOT come back on again until I have shut the engine off and restarted it. Often, it won't come on at all and it's working less and less lately. Degrading...? More often than not, it won't come on at all now, but once in a while it does...
I have replaced the underhood whatchamacallit- solenoid or actuator or whatever. (Can't remember right now) I have also replaced the on/off switch in the steering wheel. Haven't replaced the right side accell/decell switch.
Can the clockspring be causing this? The horn always seems to work fine, but a jeep tech told me that clocksprings can work intermittently. I thought the clockspring either worked or it didn't, but...?
This silly thing is driving me nuts, so any help would be appreciated!
Thanks!
Dirk
Thanks!
Dirk
