Crossmember attachment
Cut through the floorboard, lay in a strip of 3/16" steel, 12 or so inches long in the 'frame' channel. Drill through, add nuts and washers.
Or, you can do something similar to Claytons LA kit, where the brackets weld to the 'frame' and the X member unbolts from the welded on brackets.
did some looking around for pics, coundnt find what i was looking for.... but ive seen holes cut into the unibody rail, then you weld a nut onto the top of the t&t stiffener... leaving the under side flush
advanced fab/pirate 4x4 is your friend.....
your angry, yelling friend
