roosteroby
- New Jersey
Here's where I'm at I have a 96 Cherokee and I just replaced the rear main seal the oil pump and the oil pan gasket. The oil pressure instantly pinned the gauge above 80 and doesn't fluctuate like it used to prior to oil pump replacement. Jeep ran fine for a week with no leaks and weird starts occasionally. Yesterday had a check engine light which I had checked at autozone and it suggested timing which after research found out is controlled by the cps. Drove the jeep all day and had no issues then at twelve it started hesitating then died and in the process started seeping oil from the rear of the pan. This is the first time the jeep has made me tow it and I'm pissed. I don't understand did excessive oil pressure blow oil past the pan gasket? Should I now redo everything including the pump and rear main seal what else electrically would cause the jeep to die? I realize one is different than the other as far as the problems go but I cant help but think they are related in some way.HELP IM FRUSTRATED.:sure:
