beakie
- Ontario, Canada
As the subject says, it seems I am getting some odd noises from my crank pulley. It isn't so much a vibration, at low speeds, but at higher RPM's I can't hear it anymore so I don't know if its still there or not.
Anyway, at idle it sounds like a constant scraping sound, very light as if the pulley had a high spot on the back side of it rubbing on the block. I can't see anything there, but I do notice a small amount of movement/wobble when looking at it from underneith.
I have no clutch fan or pulley for it, so the belt runs directly to the alt from the crank pulley. Don't think that would contribute to anything though.
Thanks for any thoughts, help on the subject.
