I plugged the 751111 in to desktop dyno 2000 and I am really surpized. It says it will hit 319hp/351lbft with a long flat torque curve, while my comp 250h produces 248hp/346lbft again with a very flat torque curve. That is with the cam advanced 3 degrees, the 300hp number with out a power adder is too tempting to not do this. It will run me around $400 but I am willing to do it. I know I am accurate with the program too because I have files saved for all stock engines and all the stroker combos on Dinos page and the numbers are very close. I don't gain much tourque but from all my playing with the software you don't gain much until you up the displacement beyond 4.7L. The 5.0L stroker that is theoretically possible makes more 25-30 lb/ft more but I have doubts about the block strength with a 4" bore.
As far as rpms I don't intend to ever take it past 6000 and I will just up my limiter to 5500 from 5000. And with 10:1 compression premium is already what goes in the tank. I have 5.13's so the gearing is already taken care of, and I already have a ported head with only 10,000 miles on it so I don't want to go with the he$co head. I have a late model intake that I am going to mount two renix tbs on, or one renix and a smaller tb to keep the combined mm's down around 70mm. Would going gear driven timing mess with my knock sensor?
