blazinjames
- Vancouver BC, Canada
i am planning on stacking 2 and 1 inch coil spacers on my 89 xj for 3 inches of lift, if i can find zj coils for cheap i might add those also. i also plan on cutting the fenders if i need to to fit 32x11.50s on there
Im planning on doing a bastard pack in the rear. I know there is many options to what i can do for this but im looking for the best way.
how much can i lift the rear before it affecting the driveshaft angle?. I dont really want to add sye or lower the transfer case. i was thinking i could aim between 3.5-4, I have a set of non greasable shackles ive had lying aroud for a while i was going to use also. should i just get a set of xj or mj leafs? or should i go with s10 leafs?
also does it affect anything having the rear a inch or so higher then the front?
