I've got a green XJ Country, and some of the cladding looks bad. What have you guys, anyone pulled it off and just painted the body there the cladding colour?
I assume you refer to the rubber molding on the rocker pannels as cladding. If that is correct...yes. I pulled the molding off the wife's 94 country. The problem was the double-sided tape that held them on. I finally ended up using an abrasive wheel to remove all the old adhesive. The original color was black and I use a rattle can of black primer to repaint. It won't win any beauty contests, but at 6 feet you can't tell anything was ever done to it.
I have seen people just re-paint the cladding grey. Looks OK, but not real great if you know what I mean. My doors got so tore up from the rocks I finally installed a set of JRCS door guards. They are made from 11 ga steel and are bolted directly to the body. Considering where you live, a good dose of clear silicone to keep the snow and salt from rusting out the body behind the panels is a good idea. Mine started out as a 96 country edition before I got caught up with the wrong crowd.:looney:
I pulled it from both of mine. On the 96 I painted it with the spray on bedliner. On the 92 I'm still repairing the rust that was underneath. It will receive the same treatment as the 96. JIM.
I've seen Herculiner on a vehicle and I'm not that hardcore at the moment. I would not mind removing the cladding and just painting the bod the same color as the molding...
