Part 1:
So I've searched (used the handy search feature), along with a google search.
Most places I Have seen have the following specs (copied from somewhere I forget):
All 6 leaf spring bolts are: M14x2.0x120mm
The track bar bolt is: M10 - 1.5 x 75mm
LCA bolts are: M14 - 2.0 x 120mm
UCA bolts are: M10 - 1.5 x 110mm
All fine and dandy, however. I went to www.factorychryslerparts.com and they specify M14x2.00x110 or M14x2.0x120. With that said, I have also seen some people state that the 120mm is too long.
My main questions are as follows:
1. UCA size.
2. LCA size.
3. Track bar size.
4. Are the Leaf spring bolts actually the same bolts used in the LCA?
In case I somehow skipped over the tread that has the actual specs, I offer my sincerest apologies and request a link.
Part 2:
What is your dealer of choice for hardware?
Ive looked at Fastenal, Teem Cherokee (has a decent deal for 2 packs) but I found http://www.pointe-products.com/ which has super cheap stuff as well.
Any input and or suggestions is always greatly appreciated.
1. UCA size.
2. LCA size.
3. Track bar size.
Part 2:
