- NC Sandhills
Jeep is fairly new to me, but until yesterday it's 'habit' was to run at 165* -/+ while moving, then shoot up into the red upon decel or at a stop. During continuous highway-speed runs, it stayed glued at 165*. I swapped out hoses and a thermostat (180*) but this changed nothing.
Yesterday it went hot on the way to work, and I uncapped it to compare the gage reading to our lab thermometers (gage is accurate) Lots of coolant loss then
so I refilled and went home...seemed to run hot (hotter than it had been) and this morning got NO heat out of the vents, where before heat was always strong.
Thinking of replacing the bottle, put in another thermostat (195*) and replace the fan clutch and possibly the water pump. I called the parts house, and they list two clutches, a thermal or non-thermal (non therm is in stock) any clues to tell which one I want? and refresh my memory if we have to pull the radiator to swap the clutch. IIIRC (3 years ago) I did a waterpump on my MJ and I pulled the radiator for access, unclear if it was to pull the fan or the pump. If I have to tear it all open, I'd be stupid NOT to put a pump in, I think...
Any advice from the experts?
